Reelay's avatar
Reelay
Axle capacity
Is there a stamp or ID tag located on the axles anywhere to ID them as to what weight capacity they can carry? {Haven't really looked yet}
My trailer has drum brakes with leaf springs and shocks, six stud holes, electric brakes.
Trailer tag inside says the trailer weight is 12,078# empty. Just curious as to what is assembly was used.
  • Don't know how old your trailer is but the front-left tag with wheel and tire info is required, just like the door jamb sticker on the truck. Mine is almost unreadable but is there.
    It has the VIN, date built, wheel and axle info and GVWR. Since my trailer was built in Canada, it has all the weights twice: pounds and Kilos.
  • You can PROBABLY tell the weight rating for your axles by measuring the brake shoes. A call to a dealer with this information, along with the manufacturer should be able to give you the weight rating (if you can't find the plate with the rating on it).
  • You can bet they won't be over 6,000#. Should be a metal tag or sticker on each axle.
    B.O.
  • Look for a decal on center of axle. It should have model and serial #. Go to axle manufacturer website and should be able to cross reference it. Also, the sticker on the front Street side of the trailer should have axle gvwr posted there.
  • My Dexter axles just have the rating stamped into the axle itself. Somewhat challenging to find/see.
  • There should be a metal tag on each axle with load rating and serial number
