Specularius wrote:
Read my posts about that. I found out that the 'smell' they add is not regulated by the gov. It can differ from propane company to propane company. So the smell you are accustomed to may not be the same smell that was added to the propane that is already in your tank when or where the previous owner filled it.
Did you purchase your RV from a different state than you live in?
There is only 1 approved odorant for propane in North America... Ethyl Mercaptan and it is used world wide. There is an approved alternate odorant in Europe and it is still 50% Ethyl Mercaptan.
Any propane distributor using anything other than Ethyl Mercaptan to odorize propane is in direct violation of federal law.
That is not true. I went to the site for federal and state regulations regarding propane. It clearly stated it MUST have an odorant. There are least 3 different ones not just one AND 'STATE' regulations play a part in their regulations that can 'differ' from fed.
""Odorization Standards: The odorization of LPG is addressed by a myriad of Federal and
STATE laws and regulations, as well as, by accepted industry standards and practices.
""odorized using either 1.0 pound of ethyl mercaptan, 1.0 pound of thiopane, or 1.4 pounds of amyl mercaptan per 10,000 gallons of LPG, i
""WARNING: The intensity of the chemical odorant (e.g., ethyl mercaptan) may “fade” or diminish due to chemical oxidation,
adsorption or absorption. .....No odorant is effective 100% of the time. Therefore,circumstances can exist when individuals are in the presence of leaking propane and not be alerted by the smell.
""PHMSA is aware of several incidents possibly attributed to either the under-odorization or odorant fade of liquefied petroleum gas (LPG
""Propane is occasionally odorized with something OTHER than ethyl mercaptan and it may "SMELL DIFFERENT".
""Users should "acquaint themselves with the odor of the odorized propane that they are using" and should frequently make sniff tests to confirm the presence of odor in ''their LP-Gas''.
Their statements not mine.
