tko9900
Apr 06, 2018Explorer
Bedroom AC
Want to install 2nd AC in a 2013 Silverback. It has a ducted system from the lower area AC to the BR. Will the 2nd AC be able to tap into the ducted system or will I have to use a non ducted AC & just...
jdb7566 wrote:tko9900 wrote:
Want to install 2nd AC in a 2013 Silverback. It has a ducted system from the lower area AC to the BR. Will the 2nd AC be able to tap into the ducted system or will I have to use a non ducted AC & just dump all the air into the BR? Contacted the factory & they were no help at all, told me to contact the dealer which will be my very last choice.
If the factory who built your trailer doesn't know, it's not likely the dealer will know either, unless you are fortunate enough to talk to someone who cares. You could try removing the inner trim ring to the bedroom ceiling vent and look for possible ductwork available.
