telicodickie
Apr 30, 2014Explorer
best rv tires
Looking for suggestions on quality tires for my 32 ft fifth wheel. I have tried several imports and haven't been real pleased with them. ST2.35/80R16 is what I am currently using.
steelpony5555 wrote:
True, 6000 lb axles most any LT E rated tire will work, 7000 lb axles you'll need Goodyear G614 tires....
WeBeFulltimers Wrote:
The actual scaled weight on your axles is what really counts. Even if your fiver has been upgraded to 8k axles the LT E tires will be fine if your total axle weight does not exceed 12,168 lbs (excludes pin weight). Or if you have accumulated excess tire money you can waste some of it on 614s
