rhagfo
Nov 15, 2021Explorer III
speediq99 wrote:
Hello,
What is the best sliding 5th wheel hitch out there?
2022 F350 crew cab diesel 6.5ft bed
Towing 14k 40ft 5th wheel
Side question, are these things easy to install if you have the holes in the truck?
Thank you
MC
I don't think Ford sells a SB F350 DRW, so you should be looking for a bigger TV, as a SB F350 SRW will only have a GVWR of 11,500# and base on your other post you have way more than a 14,000# 5er.
Grand Design Momentum 376TH, these are the specs.
UVW1 15,900 lbs
Hitch Weight 3,250 lbs
GVWR 20,000 lbs
Length 41' 3"
Height 13' 5"
About Fifth Wheel Group
