Cummins12V98
Nov 15, 2021Explorer III
OP I think you need to look at the truck specs again. It'a all in the details!
"IF" that 5er is a triple axle and it has 15% pin weight I suppose it could handle it with it's 3,300# pin weight. How does that with a HEAVY Pullrite hitch and other items compare to your RAWR???
I am assuming this RV is a double axle and the REALISTIC pin will be 4,200# at 25%. Also just because it says 16,800# it sure doest stop gaining weight! My DRV has 21k GVWR and it actually weighs 24k with a 6k pin.
Unfortunately people all the time get SUCKED INTO these so called "RATINGS".
Either start looking at DRW trucks (RAM makes a SRW Dually) or start looking for a lighter say 14k GVWR RV.
Solitude 378 MBS.
UVW1 14344 lbs
Hitch Weight1 2686 lbs
GVWR 16800 lbs
Length2 40' 2"
Height5 13' 5"
Solitude 378 MBS.
UVW1 14344 lbs
GVWR 16800 lbs
Length2 40' 2"
Height5 13' 5"
About Fifth Wheel Group
