MFL
Nov 15, 2021Nomad II
Above poster is correct, you need to more understand your trucks axle/tire limits. You will be at the very limit, or just over. You will need a lighter hitch than the Superglide.
While your truck could easily tow a 22K FW it could not carry that wt.
No one backs their boat, or TT to 90 degrees, and a FW is no different. A little common sense, and awareness, is your friend. That FW is tall, need to be aware of above. When turning in continuous arc, or backing tight, awareness is key. These things are learned quickly, and most know to pull ahead, straighten a little, then continue backing, no matter what you are towing. 90 degrees..NOPE
Jerry
Jerry
About Fifth Wheel Group
