Mile High wrote:
tahoemc wrote:
X3:). I first level side to side with a board ramp, then disconnect and hit the auto level. It is calibrated to the bottom of the fridge. I also use bubble levels mounted outside for redundancy.
Curious why you use a board ramp first? I just hit autolevel and call it a day - if I get overstroke, I retract, add some blocks under the overstroked pistons, then hit autolevel again. I will level even if it means both wheels on once side are off the ground.
Just personal preference I guess. We tend to camp in mostly unimproved campsites or boondock - even a lot of NFS and BLM designated campsites around here are very uneven. Using the ramp seems to help overdoing the autolevel sequence and helps keep all 4 tires on the ground.
