bpounds
Jun 12, 2017Nomad
lovemy5thwheel wrote:
Question: If probiotics are good in the holding tank and some of the RV stuff has them in them, can we just add our over the counter probiotics that we take to our holding tank? If so how much would you add. I was thinking of Dawn, Water Softner and Probiotics. I would think that it would be healthier and cheaper than buying black tank additives
I think the pith of your question is, would it be helpful to add the probiotic capsules that you already take, directly to your black tank. To which I would reply, you are already adding those probiotics every time you use the toilet. It would be silly to drop capsules into the black tank, in my opinion. Either way you add them, directly or post digestion, they are not going to do a thing for your black tank.
All you really need is plenty of water. We use the pillows you drop in, simply because they are cheap, easy, and simple. I'm not sure there is much benefit, but I am sure they don't hurt anything. Geo method and the like is no better. How could they be better, when there isn't a problem to solve? And I don't need the complexity or mess of several liquids. Drain the tank, close the valve, open the toilet and run some water, and drop a pillow. Done.
I believe the absolute best maintenance you can do to your black tank is to drive with some contents. Try draining your black tank when you arrive at your next destination, instead of just before you leave the previous. It's called agitation! And it liquefies the contents better than any additive. Even better than tank rinsers.
About Fifth Wheel Group
19,039 PostsLatest Activity: Jan 28, 2022
