David1inMarylan's avatar
Jun 15, 2015
Brake issue - Poor braking Thor 2005 Victory Lane 36'
2005 Thor Dutchman Victory Lane Toy Hauler 35SRV twin axle
Thanks in advance. I've owned this 5er since 2008. The first few years I did a little towing with it, in the past few years I've elected to leave it to my campsite (a peaceful 8 acre parcel with full services, with only family camping) manager (brother) to pull it out in the late fall, and he is kind enough to put it back in place in the spring.
So, when I say that the brakes seem to be lacking, it's not just my word, and not just my vehicle (or brake controller). My brother says it's the most challenging to remove and get into storage, speaking of braking.
I tow with a '99 GMC K3500, the usual vehicle my brother uses is a 2011 Chevy 2500. We both recently talked about how the brakes on the toy hauler seem inadequate, even with the controller turned up (in either vehicle). (BTW, while I have limited experience towing, my brother is very experienced)
Why ask this question now???
This fall, my wife and I plan to bring the camper home to Maryland (from it's current location of the Finger Lakes in NY). I have some interior repairs to do, and we have some interest in remodeling some). We go up regularly to weekend camp with family, and spend our vacation there as well. So, in the summer period, if there is work to be done to improve these brakes, I could perform any recommended troubleshooting and or repairs/replacements that the forum could offer up to me.
If this is covered in some other area, I do apologize for re-posting, I have done searches, but didn't seem to find the jewel that I was looking for.
Hey thanks for reading, and if you have any input, thanks for that too.
  • Thanks everyone for the replies, I went on vacation armed with knowledge and tools, and then ended up purchasing a 2015 Big Horn. Hopefully this string will assist others.
  • Golden, bearII,
    Thanks for the input. I'll add those to my list for my next visit to the camper.
    I do have a question, is the brake adjustment for a rig like this similar to that of a drum brake on a truck?
    I do > 80% of my vehicle maintenance, so I'm not shy of working on the brakes, just want to educate myself prior to the drive to it.
    When I replaced the tires a few years ago, I did verify that the brakes did engage, however, was really only a go/no-go test. I was alone, and while reinstalling the wheel, I connected to the truck, and wedged a piece of pipe between the drivers seat back and the brake petal. All four wheels did engage, however, didn't think to check for voltage, and was unaware of any adjustment.
    I do appreciate this info.
  • Someone mentioned that they replaced the #12 wire from the brake controller to the trailer. Before the repair, the best voltage they would get at the brakes was only about 8 volts and about 2 amps per brake.
    After changing to #10 wire, they where able to get 3 amps to each brake, and 18 amps total to all three axles. It could have also been a poor electrical connection, and the new wires solved that problem as well.
    If the trailer is more than 10 years old, improved wiring is the first step that I would take. Then inspection, lube everything, and proper adjustment of the brakes should solve the problems.
    You basically eliminated a brake controller problem because the trailer brakes perform bad on two trucks.
    Also with the brakes on, take a compos around to all the tires. it should point toward the magnet, not north when the brakes are applied. Do not apply the brakes to long, as you can overheat the magnets. If your truck is not there, just pull the plug on the break-away switch, and put it back in. The converter and battery will supply full 12 volt power to each brake while the plug is out.
    Good luck!
    Fred.
  • Since it has basically sat for many years I would take the brake drums off and make sure everything is well lubricated and free of rust. Grease the bearings and put the drums back on, set the bearings and adjust the brakes properly.
    In addition, I would test the output of the controller to make sure you are getting enough voltage. Check the trailer plug to make sure the contacts are clean. Also check the wire connections at each brake to make sure you are getting good contact.
