cummins2014
Oct 20, 2020Explorer
Njmurvin wrote:
Assuming you can hit the cab with all conventional non-slider hitches, your best shot at avoiding a slider is likely the Andersen. The hitch, itself, gives you 5" of setback from the cab. Then, add about 4" to that if you can get away with the standard install of the kingpin adapter. Assuming your pinbox has clearance from the bedrails and tailgate in that position (as mine does), you gain a healthy 9" in total.
I had a Superglide in my previous truck and I loved how I never had to worry about hitting the cab. What I didn't love was getting the hitch in and out of the truck and its robbing me of 250lbs of payload. It literally takes me 15 minutes to install my Andersen (all 38lbs of it) and I take my time. My truck has a slightly longer bed (6'10") and I have miles of clearance to the cab in tight turns.
My kingpin is at the same distance from my cab with the adapter for the Andersen in the forward position putting it closer to the cab as it was with my Reese slider in the tow position. I have no issues backing my fifth wheel .
We just returned from a hunting trip, and as always I have a tight turn to get into my RV pad beside my home . The pad is 10 feet wide , my house on one side ,and property line ,and trees on the other, its a tight fit . I have to crank it pretty tight ,not an issue . I would say I am in the 70 degree range, a lot tighter then I want to on dry pavement., and cement. As one asked can I go 90 degrees ,no . I can get close ,but getting in my driveway is as tight as I have ever had to go.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
