Ivylog
Apr 22, 2016Explorer III
First you said non-GFI's not working and now GFI not working, which is it? Do you have a inverter? If so check the breakers on it. I would test the 120V output of each breaker to find the breaker that is bad even though it's not tripped.
If you do not have 120V tester then I would turn the breakers on/off half dozen times to hopefully get the bad one to reset.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
