Tex250
Apr 23, 2016Explorer
golf_bears wrote:
Tex250,
First of all your description of your problem is very confusing and difficult to follow. Not trying to be an a__ hole here but I'm really struggling to understand your problem.
Also, some suggestions have referred to your inverter. I doubt you have an inverter but rather I believe you have a converter. So take note of that fact. These two components perform completely different functions. 30amp systems don't usually have inverters.
As suggested a few times already, turn off all the breakers and then turn them on one at a time. Turn one and see if you have power to what it controls. Then turn that one off and turn on another breaker. After you have performed this check come back and tell what you have found.
First off thanks for all the suggestions this trip will be ok and I'll work on trailer when I get home.
I only have 6 total breakers for this trailer:
1-main 30a
2-GFI 15a
3-microwave 20a
4-gen 15a
5-Waterheater 15a
6-AC 20a
This is how panel is labeled. All my 110 outlets run off of my GFI labeled breaker.
All my GFI labeled outlets work. None of my NON-gfi outlets work
Sorry for any confusion. It's just weird that gfi outlets work and the non-gfi don't, they are all on the same breaker.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
