Joe_Way
Apr 23, 2016Explorer
A guy I know hauled his trailer 80 miles to get the fridge repaired. Turned out the fridge outlet in the outside access area was a tripped GFCI receptacle. Reset the GFCI, problem fixed. If you have a similar setup and your "NON-GFI" outlets are wired downstream of the fridge outlet, that would cause your problem. Is the fridge working on AC? If not, look for a GFCI in the outside hatch.
Joe
Joe
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
