Jlschuma wrote:
I went a few years newer and got 2003 4X4.
Now I need to get the truck set up for the camper. I am thinking airbags and new Bilstien shocks. The tires are rated at over 2400 pounds each which is over the axle rating of 3900.
What are the best changes anyone has made to a 1500/150 for towing?
The pin weight of the fifth wheel is 884.
YOu should not have any trouble with the 5.7 I pulled a 34' with a 5.7 and 3.73 gears. If you beef the suspension a bit you should be able to do OK if you don't have gears lower that the 3.73. If mine had 4.10 gears I could have gone most anywhere. Good Luck
