BigDogF250's avatar
BigDogF250
Chasing Electrical Gremlins - Questions
So, keeping the story short, trailer was working for 8 hours after travel, then in the middle of washing my hands, the whole trailer went dark, losing all power.
At all times the battery checks at 12v, but I will load test tonight.
The ?'s
- Why does the converter control the ground? From the frame to the converter then to the ground bar where all other connections go. I add a direct ground and that helped (for a while).
- Do I need to keep it that way? Seems like a recipe for issues.
- When not working I was seeing as high as 3v and as low as 1 volt at the inside of the trailer. Battery checked at terminals, 12.8v.
- When running on generator it's fine, meaning the converter seems to be working. So I put about 16 hours on the gen this weekend.
Welcome any comments. I am very familiar with 12v wiring, but this one has me stumped. My next plan is to replace the wiring and fuses from the battery to the panel with a single cable, probably 4 gauge unless something bigger presents itself. I really have no intention of adding an inverter unless the converter is faulty, my camping style works well with 12v. Then bigger cable to the batteries and maybe 2 outlets live on the inverter.
That and 2 flat tires on the MX bike made the weekend less fun but the tequila and beer were cold so it all worked out.
  • There should be a converter case ground.
    Then there is a 12 volt negative that goes to the 12 volt system.
    Don't get them confused.
    I go along with a circuit breaker at the battery(ies) or in the 12 volt DC panel.
    Another thing to do is go through all the 12 volts connections. Make sure they are clean, have electrical grease on any tinned copper or aluminum connectors and buss bars, and insure they are tight.
  • Some RVs have a cb where the battery connects to the distribution buss. But then there would be no 12v into the house. On mine it is tiny hard to find. Meter would tell you if 12v is getting across to the distribution lines. It just isolates the batteries, Good luck.
