SabreCanuck
Nov 06, 2015Explorer
Learjet wrote:
2015 Wildcat 317RL advertised basic weight.... 10,085
Yellow sticker with all options as delivered..... 10,976
Cat scale full water and all my stuff...............12,020
Edit...more info:
Truck with ME in it, full fuel, trailer full water
Steer axle 3,900 (max front 4,250)
Drive axle 5,440 (max rear 6,100)(7,000 lbs on F350 with same axle, added Timbrens to my truck)
Trailer axles 9,720
Gross Vehicle weight 9,340 (10,000 rating)
Gross Combined weight 19,060
Pin weight @ 2,300 (2,460 minus truck hitch, truck not weighed with hitch installed)
Hang on.. This cannot possibly be true. Your signature shows you have a 3/4 ton truck and you are well within all maximum weight specifications hooked on to a 10,000# fifth wheel and ready to camping? (BTW So do I). I've read numerous times I should have a 5 ton dualLy in order to be anywhere near SAFE.
So, this cannot be true.
It has to be hear-say.
It must have been empty, not loaded.
The scale cannot possibly be right ;)
The weight police around here are 100% sold on the fact that you would require a bare minimum dually pull any trailer above 8000lbs...
Kidding aside, thanks for this REAL WORLD update if in fact it is true because just like the weight police you can't believe everything you read on the internet.
I feel better now.;)
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
