garyp4951
Apr 04, 2016Explorer III
minnow wrote:garyp4951 wrote:wilber1 wrote:
Did you have the blocks made or from some other source?
http://www.trailerblocks.com/
This company is in Canada, and the quality is outstanding.
Did you do the work yourself? If so can you provide a step-by-step? Did you do just one side of one axle at a time? I may need to do this to mine as well as I've got a new truck on order and it's going to be taller than what my setup is now. Thanks!
I put jack stands, and wood cribbing in front, and behind the wheels on both sides, raising each side a little at a time. The wheels were still barely touching the ground, and I used a floor jack, and 2 more small jack stands to remove the tires, and support the axles. Then did one side at a time before installing any tires. I see now why they charge $500 plus to install this kit.
I agree that some lateral cross members would add strength, and will probably do this. I had Duravis 250's on my last 5er, and my next upgrade will be tires, and maybe wheels. I have not weighed yet, but in the 9K range gross. My last Silverback was 11500k, and this tows much better with an 03 Ram 2500 CCC.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
