flyfishing48's avatar
flyfishing48
Cover for Satelite cable or roof
Our 5 er is pre-wired for a Satelite dish, the roof is marked where to drill a hole to access the cable. My question is what's normally used to cover the hole once the cable is fished through the opening?
I should add I am not going to use the cable for a satellite dish, it will be connected to a weboost antenna.
Thanks in advance for any help.
  • I just knew this idea was " too easy".
    Thanks for the heads up.
    So all rg6 is not the same then?
  • The weBoost uses 50 ohm coax cable. TV coax cable is 75 ohm and will not work. You will have to run a new 50 ohm coax.
