tcamper's avatar
tcamper
Crazy issue with Brake Controller/system - Need Advice
Last year at this time I had an incident on a local road at 40ish miles per hour with a quick hard braking …… and my trailer brakes locking up and ruining my 1 year old tires (flat spots).
I took the trailer to a trailer mechanic and they adjusted my brakes on my 1 year old 2017 310GK. They said my brakes were terribly out-of-adjustment.
I also bought some new very expensive G614’s …. Set my gain on 4.5 and all my problems were resolved….no breaking problems for a year.
Until yesterday when I was taking my trailer back to storage.
All of a sudden …..I was traveling about 30-35 mph and had another rather quick kinda hard braking incident (a DA in a beat-up pick up truck pulled out in front of me) ….. and I hit the breaks and had a short tire skid and a brief smell of burnt rubber.
I examined the tires as best as I could and did not detect any damage or flat spots. I did not lift the trailer to examine.
Once in the storage parking lot I triggered the manual lever on my break controller and there was an instant slam of the breaks ….. like my controller was set to 10.
I lowered my controller to 1 for the time being.
I have a 2015 Ram 3500 Longhorn with the OEM IBC and a 2017 Grand Design Solitude 310GK
What is going on guys?
  • A 40 mph skid flat spotted the tires so bad they had to be replaced?? Seems odd.
    Yes need to adjust the brakes more often or consider disks.
    Sounds like a controller issue that should be covered under warranty. Has the dealer checked it?
  • Sorry all .... yes ....
    I have edited the OP
  • Brake controllers aren't set and forget and I would never trust some shop to adjust mine.
    You need to adjust them to suit your current driving conditions. In a panick stop, weight will transfer and it's likely wheels will lock. That's normal.
    The brake system on a trailer is not sophisticated like that of your tow vehicle.
  • Fulltimer50 wrote:
    It is always helpful to know more about the product that is giving you problems. Make, Model, etc :)
    While I agree with this post, it would be safe to bet that OP has the Ram IBC that should be OEM in his 15 3500. I know some Ram owners had issues with the IBC, and moved to after market, with better results. A Ram owner may better remember the problem/fix with some Ram IBCs.
    Jerry
  • It is always helpful to know more about the product that is giving you problems. Make, Model, etc :)
