dieseldan723 wrote:
OK, this is weird. I went out this morning. Pushed the PRIME button and tried to start it. It did not start. I went out and took the cover off and there was gas everywhere. It wasn't quite dripping out the bottom but there was a layer of gas on everything. I could wipe it up with my hand. As I said earlier, it really smelled like gas, now I know why. I went back into the trailer and the gas gauge showed EMPTY!
The last time I looked it was at 3/4 full.
I am concerned the gas gauge is not working properly. In hindsight it does seem weird to me that I could run the generator for nearly 7 hours AND fill the quad once (5 gallons) and still have 3/4 of a tank. I did move the trailer this weekend and maybe that caused the sensor in the tank to become "unstuck". There is no way it could go from 3/4 to empty just sitting there unless 1)there is a leak 2) someone is stealing my gas - the trailer is behind a locked fence 3) the gas gauge is not working, or a combination of the above.
My guess is that it won’t run because it is actually out of fuel but I don’t want to put more in if there is a leak. I probably should take it in as it’s still under warranty.
Been following your thread... timo
As Thunderbolt said, carb needle and seat probably are leaking/sticking from being gummed up. Probably an easy fix, but more than likely, the rest of the carb is not metering fuel correctly either. And with staked in jets,tiny tiny af passage ways, no gaskets or parts available, a getto parts-less rebuild is not a solution for most.
IMO, best way for you to go now, bite the bullet and spend the $169 for a new carb. And always run the max ratio amount of stabilizer, STA-BIL or SeaFoam in your fuel. And still run it once a month. Might get away with once every 3 months with max fuel stabilizer, but don't push it.
Some say drain the float bowl after every use before storage. This might work/help also, but might also dry out gaskets/orings and also cause leaks eventually. I've done it, but not regularly.
Not sure how your fuel tank/fuel pump is set up on your TH, and if its possible for lots of the fuel to siphon out of your tank from a leaking needle and seat in the carb. Depends on the height of the pickup and fuel level in the tank, fuel pump, the carb height, and angle of these components in relation to each other.
Most Onan carbs have a fuel solenoid in the bottom of the carb that should prevent this. But these solenoids are one of the main problems with the Onan carb. These solenoids get gummed up and stick closed or open.
I have seen a leaky needle and seat drain a complete fuel tank on other engines/vehicles. And suppose it is entirely possible on the Onan with the right set of circumstances.
Oh ya, If you don't do anything else, do the up date safety bulletin to your genset. It consists of removing the secondary fuel filter from the carb fuel inlet. And replacing it with a new Onan barb fitting.
Supposedly, this secondary filter has caused fuel leakage and fires. It is redundant and not needed. Onan does away with it since 2010-2011.
I added another clear plastic fuel filter in the fuel line before the pump under the toy hauler because I cut my fuel line for trouble shooting purposes, so used a fuel filter as a splice coupling.
Would not recommend adding any other filter inside the gen-set compartment. A good short properly routed fuel line direct from the pump with no splices is best in the genny compartment.
The old Onan Carbs secondary filters length and weight, combined with engine vibration with fuel hose weight on the end of it, caused filter to loosen up and leak at the fuel inlet fitting on the carb.
The new retrofit fitting from Onan comes with leaklock/locktite on the fitting threads. Screw it in very tight, it is a npt fitting. But don't break it or your carb.
We want to avoid all fuel leaks, a TH fire is to be avoided at all cost imo...
jmo
