devildog1971
Aug 17, 2018Explorer II
7500 cummins onan
how often should the oil be changed in the onan 7500 watt diesel if only holds 3 quarts of oil, and ours gets used a lot in the summer. one other question I did not do enough research when I bought our class A and bought one that does not have a slide out generator, Can you get to the spark arrestor and air filter without dropping the generator on the ground, those of you experienced with these generators please let me know what items can be serviced without dropping the generator, and what service requires dropping the generator thanks in advance for your help and advice. One other thing how hard is it to drop the generator to the ground to service it
