Now weigh your truck/trailer combo in fully loaded trim, as if you are on a trip, then fit the inflation into the tables. Remember how many tires you have on the trailer and divide the weight by the number of tires. That is how much load each tire will have to carry.
I've towed trailers since the early '60 for recreational and mostly in my hauling business using same size trucks and trailers we RV with.
Pressure needs on our trucks vs tire pressure needs on a trailer are apples vs oranges. Completely different operational environment.
A couple of points on using just a minimum pressure from minimum pressure charts.
One is loads on tires on a trailer unlike tire on the truck, constantly change especially in strong side winds can over load the tires on the down wind side. Using minimum pressure doesn't account for the over load.
Another point is simply dividing the trailer gross axle weight by 4 tires doesn't take into account one side of the trailer is heavier or one end of a axle is severally over loaded. Minimum pressure charts doesn't account for that over load either.
fifthwheelstreet.com
Step #5..
Selecting the Correct Tire Pressure for Your Trailer
We at Fifth Wheel St. no longer recommend adjusting trailer tire inflation pressure below the maximum load PSI rating molded on the sidewall (and only if the wheel/rim is appropriately rated) regardless of the measured scaled weight of individual tire or axle positions for all multi-axle trailers.
However, we do strongly recommend weighing individual trailer tire positions to ensure none of the axles or tire positions are overloaded. Reports have shown that trailers do not have equal weight across all tire positions. Some RV load configurations may reveal as much as 20% difference between the front and rear axle. This especially true for Toy Haulers. It is possible that mismanaged trailer load distribution will cause one end of an axle or a tire to be overloaded. It has been stated, but never confirmed by any RV Weighmaster, that there are many RVs traveling on the road with at least one tire or axle side overloaded. The only way to ensure tires and or axles are not overloaded is to weigh each tire position on your trailer. Unfortunately, attempting to obtain accurate individual tire position weight is practically impossible at all truck scales. View our list of recommend RV Weighmasters here.
- See more at: http://fifthwheelst.com/step5.html#sthash.FIAc3k0Z.dpuf
