- CHV_FRKExplorerThe option was for the high gloss gel coat. Base is kinda like gel coat. I think it's fylon or something like that. You can see the texture of the fiberglass though and you can't really buff it as well. The actual gel coat is additional mass on the outside of that. Adds I think about 200lbs to the trailer. It can be buffes and also smoothes out the surface.
- L_MMusicExplorerMight do it, Mrbuck50. However, we've had ours in full-time use for almost three years without issue, so I'll try a repair first. Taking it in for a free estimate tomorrow (again!) Hopefully, they'll diagnose it this time!
- mrbuck50ExplorerL&MMusic......replace it with a GE. We did and never regret it. Apollo = JUNK!!!
You will have to modify the cabinet to the left of the micro, but its worth it. - whporwilExplorerHi Dana, Don't all our campers have a gel coat finish? Jayco offers an optional clear coat finish we paid $1995.00 for. It probally has another name.
- petekerwienExplorerCheck around the floor of the slide. Is carpet rolling back under? Any objects blocking complete closure? Check notched shaft underneath, is it clean or is there a grease/dirt build up preventing complete closure. Before attempting adjustment, check all around the perimeter of the slide inside and outside. Something may be preventing full closure.
I have reluctantly become experienced in slides.
Good luck. - CHV_FRKExplorerClear coat or the gelcoat? On the corner I'm sure the slide probably needs to be adjusted. Ours isn't that bad on that slide, but looking at the adjustment I would probably rather have someone who knows what they are doing adjust it.
Not sure on the convection oven.... - whporwilExplorerWe have an RLSA with the delux entertainment center and when it is closed it is not sealed. In the rear corner on the floor you can see lots of day light. It also appears that the clear coat option we have is turning yellow. Is anyone else seeing this?
- L_MMusicExplorer@eaherrmann -- I didn't get notified of your post -- not that I have any ideas for you anyway. Sorry.
We took the microwave/convection oven to an appliance repair place here in Naples for a free estimate. They can't find anything wrong with it. Ergo, great news for the Apollo...but now to track the problem...any ideas? - eaherrmannExplorerOK, now what did I do? I did the programable thermostat upgrade a while back and this past weekend when I ran the heater the AC fan ran as well. Any ideas?
- CHV_FRKExplorer
loydt wrote:
Can anybody confirm our axle info? Are they Dexter, 7000 Lb? Getting a quote to have disc brakes installed.
I'm pretty sure... I have some pics of the stickers somewhere if you need them.
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
