GJGAR's avatar
GJGAR
Diesel Fill up
I have a 33' 5th wheel being towed by an F350 diesel. I always fill up in the auto lanes but it can be a real challenge at times. If I go to a flyin J or a Pilot station can I fill up where the trucks fill up?
I remember years ago going to a station and the diesel pump stem was too large to fit in my truck. What has been your experience?
  • Yes, you can use the truck lanes at Flying J and Pilot if you don't mind getting hosed about 20 to 30 cents more per gallon.
    Ken
    A 2017 will work just fine, and if you have a Good Sam card, you get a discount at the pump with fuel purchases. My credit cards work flawlessly at the pump at FJ and Pilot.
  • WE-C-USA wrote:
    Also, you may have to go inside with your CC, to start the pump.
    Then fill, pull forward and go inside to pay.
  • Also, you may have to go inside with your CC, to start the pump.
  • Side note...the pumps in the truck lanes pump fuel extremely fast, be careful or you'll get a nice bath.
  • The problem was on a previous truck, not on my present truck. Presently I have a 2017 F350 Diesel. I will go to a local truck place and do a test. If it fits, it will make filling up a lot easier. Thanks for every-bodies input.
  • If you have had a previous experience where the pump wouldn't fit your truck you must have the small opening. If that's the case you could not use the truck lanes. I would look into changing the fill neck on the truck. I would find it very un-handy to not be able to get diesel from big truck pumps. Both my Chevy diesels have had filler necks big enough to do it.
  • I have a '06 F-350 and if they don't have a RV lane, I use the Truck side, and Haven't had a problem or issue. Just remember to move your truck / Rig as soon as your finished fueling. Good Luck and Happy Camping !!
  • You don't mention the year of your F350 both my 09 and my 17 accept the larger nozzle. Don't know about years earlier than 09.
