SDcampowneroper
Oct 17, 2019Explorer
Your hich should not have allowed more that a 7 deg. side to side tilt. If you have the minimum recommended 6" bed to overhead clearance, the hich would limit the roll between tow and towed, making the truck tilt with the trailer when that limit is reached.
Should you also encounter a high point vs a low point dip, the risk of bed to trlr. increases.
Raise the trucks 5er hitch, or lower the pin box to give better clearance.
About Fifth Wheel Group
