Celticman's avatar
Celticman
Dometic Refridgerator stopped cooling
Model # RM3862
Pr3oduct# 92114659
Ser# 20900070
2.7 amp
Just wondering if I have to buy a new unit or is there something I can do to breathe life back into it? Fuses are good. I have power. Nothing burnt or smelling like it.
We got a lot of rain and the fifth wheel became 1/4 bubble off level according to the fridge level. Thanks for any ideas.
  • OK ....
    So the 120V AC is NOT working
    Have to start at outlet fridge power cord is plugged into
    Does it work? (plug ANY 120V AC item into it and verify it is hot)
    If NO..check for tripped 120V AC Circuit Breaker
    IF YES
    Then need to check the AC Fuse on the lower circuit board
    Glass Fuse....5a most likely
    Is fuse Good....120V AC on Both sides of fuse?
    If NO...replace fuse and replace heat element
    If YES...then need to check that you have AC Voltage on circuit board where the Electric Heat Element leads connect.
    Typically when no cooling on AC
    It is bad heat element
  • I'm no refrigerator guy so I'm somewhat out of my area, so forgive me if I don't know proper terminology. I took the access panel off again. The pipes are cool above the "bottle"; I'm guessing the refrigerant. The pipes below the "bottle" are a little warm as is the "bottle" itself as is the rectifier (ammonia exchange).
  • All display lights work as does the interior light. Wires and fuses are good. No ammonia smell. Was working well until yesterday. The Fridge is original to the unit, it is a 2002 fifth wheel.
    I haven't tried it on gas as propane is expensive here. I was wondering if control board or relay.
    My multi meter has a broken wire so I've not been able to check things as I'd like.
    Not much daylight when I get home from work.
  • New units can be very expensive unless you are thinking about a residential unit. As stated earlier if there is/was no ammonia smell and there is no yellow powdery residue around the gas burner (indicates a cooling unit leak) than a repair will be A LOT less expensive and less invasive than a replacement. Even if there is an ammonia smell or yellow residue it will still be a lot less expensive to repair.
    If the cooling unit is ok then there isn’t much else left.
    Control board, Blown fuse, Rodents ate wires, all fairly inexpensive.
  • W/O more info very hard to post anything but guesses
    Here are Common Issues....LINK
    Go thru above link and do a little troubleshooting
    Post more detail info such as:
    No Display/Interior Light.
    Has Display Lights....doesn't cool on AC Power
    Has Display Lights....does/doesn't work on propane (no spark/no flame---has flame/no cooling
  • A little more info would help. How old is it, like mentioned , not working on gas or electric. If no ammonia smell, that is good. I agree a little off level, should not have caused the problem. Was it working great just recently, or not used in a while?
    Jerry
  • What is not working....electric or propane side or both?
    1/4 bubble off level is nothing so I can assure you that is not the issue.
    Before you talk about replacing it, I'd have a mobile tech in your area check it out....it would be worth the service call charge.
