Macman83 wrote:
I have a Voltage 3905 that scales 16,200 lbs. empty that I pull with a 2010 F-450 that scales 9260lbs with me and 1/2 tank of fuel. GCWR on the truck is 33K lbs. and the bigger brakes and wheels/tires do a great job. On the scale the pin weight was calculated to be 3720 lbs unloaded! That would be a lot of weight for a 3/4 ton truck, and was too much for my old F-350 SRW, even wit the airbags. Just putting out there what numbers I have been seeing.
The last half of this post is just about identical to my problem.
The pin weight and overall weight was the deciding factor for me. I too put airbags on my previous truck and the Voltage was just too much for that truck.
