mtofell1
Feb 14, 2016Explorer
Equal bearing for both sides of landing gear?
My first 5th wheel had separate controls for the landing gear so this was never an issue but my new one is just one switch. How concerned do I need to be about getting both sides of the landing gear to start bearing weight at the same time? I know it's never going to be exactly the same but is using 1/2" plywood scraps enough? As in, worst case scenario one hits 1/2" before the other?
Unless I'm on totally level ground they never hit exactly at the same time. I just don't want to bend or twist anything excessively... but also can't imagine it's necessary to use shims every time I setup either :)
