rhagfo
Feb 19, 2017Explorer III
donn0128 wrote:
From my proapective and having towed a similar weight fiver with a 2500HD Im going to say you will,hate the experience.
My 2004 similarly equipped with two adults and a large dog scaled at 7500 pounds. With fiver hitched scaled weight was 10,500 pounds. RAWR was way over tire rating, and it sagged like a mother. Pulled fine thanks to the D/A combination, but was simply not enough truck. Up graded to a dually and the difference was night and day. There is no way in heck I would suggest you will be OK. But, you will need to find out for yourself whether your comfortable or not.
Donn, not sure how you can make a statement like "Im going to say you will,hate the experience"!!
If the 5er truly has a 9,900# GVWR and not dry weight, even if dry with a 1,574# payload that is still only 11,474.
I don't know how you were over rear GAWR and tire, minimum tire would be 245/75-16 at 3,042# capacity with a rear axles of 6,084#, I am still 500# shy of that and I have a bunch of stuff in my bed mounted tool box.
We need to OP to post some real weights, to even have an idea if he will be close. Maybe I am lucky as my 2001 Ram was optioned with a Camper Package, and the optional 265/75-16 tires at 3,415# capacity each.
I do agree that it is irresponsible to state no problem go for it. There may be decisions the OP needs to make about the TV's GVWR.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
