Campinfan
Feb 27, 2017Explorer III
My freshwater tanks are in front of my axles so that would add pin weight to my set up. Also, if you load anything behind the axles, that will lighten your pin weight because pushing down on the back will lift the front a bit. When I had my F250 I used 20 lb propane tanks instead of 30 lb tanks. Not sure how much that saved but 30-50 lbs here and there could help.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
