jo1991's avatar
jo1991
fixer....walk away or give it a try..1992 kountry aire
hi to everyone, new to the forum today. topic of discussion...1992 newmar kountry aire. my husband says no project trailer for him...i am still open to bringing her home if she isnt too far gone. we have had one bumper pull that we just sold, 1988 amish built that we ended up having to rebuild the front end due to water damage. sold it and now looking for a 5th wheel for weekend camping, not much pulling it at all. i am not a fan of cheaper built units, so this lady caught my eye and went to view it. since most of the fixing will have to be me, and yes, i am a lady...lol i need some opinions. most of you are dealing with much higher budgets then we are, but we are looking to spend 6000 max, so have been looking at models built in the 90's. so here is what i saw looking her over.
exterior- no waves in sides, one utility cover gone or in the storage underneath, a few rusted exterior utility covers, roof seemed to be ok, ladder was sturdy climbing up, one window was removed and taped up (window was found inside), she had been using an additional window unit, neither slide runs( she says it needs a switch??)bedroom slide not completely tucked in at top, sticks out 1-2 inches. she has siliconed every inch of molding and windows..this is one of my biggest issues..how hard is it to remove lots and lots of silicone and seal everything properly..this is windows and trim pieces.
interior- ugh...first off, cabinetry is nice quality bleached oak, counter tops are good, stool is porcelain, shower is nice, w/d which we would remove. the bones are all good inside. no water damage noticed from top to bottom on any walls, ceilings, cabinets and all window jams. flooring i would remove it all and put in something different, it is nasty. the sliding closet door in bedroom, had one frame that needed mirror replaced, sliding doors in bathroom needed adjusted. mostly cosmetic inside. my biggest reservations are...tubes and tubes of silicone that need to be removed from exterior, i would remove each window and tape them properly. non working slides. switch, maybe..but possibly motors???? ok, here is the finale...i may be able to purchase her for between 3500-4000. whats your thoughts folks??? thanks!!!!!
  • By the time you are finished fixing it up you will have spent more like 17K if you do it right. Shoot the running gear alone could cost you 1k and that's if everything is in working order. If one of the axles are bent forget the one 1k. Tell you what I would do. If the person that owned it wanted to give it to me for free ...... I would think about it ...But not very long.
  • MPI_Mallard wrote:
    "RUN FORREST,,RUN"
    ^^^ This!!!
    Money Pit comes to mind.
  • The $3500 asking price will turn and burn into A LOT more.
    Add to that, "My husband says NO project trailer for him."
    If you both aren't on board with this project...I'd walk away.
  • First: Welcome to the forum.
    Second: And remember you, asked!!!
    IMHO: If one of you or both are trained master wood craftsmen, also trained in steel & aluminum welding, master plumbers, master electricians, master mechanics to handle the axles and running gear, have a fully enclosed garage to work on this 5'er indoors out of the weather, have a very well stocked tool crib, and have a checkbook with an unlimited bottom, then I'd say go for it and have fun with your new hobby. Otherwise, leave that sucker where she sits and find a new hobby other than RV'ing...or raise your budget significantly. With a budget of $6K for a 5'er, you're not going camping any time soon. You're going to spend your weekends from now till who knows when restoring your new 5'er hobby in hopes to get it on the road some day. Unless you're just dying to buy a hobby, consider taking up hiking or golf. Good luck.
    Happy camping!!! See y'all down the road!!!:)
