klr650goldwing's avatar
May 11, 2018
Fuse locations 2004 f350, brakes not working
The brakes do NOT work on our 5er. The repair shop suggested I check the fuse before we schedule an appointment. He thought it would be under the hood. I don't see a fuse panel under the hood. I do see a small black box with 4 relays in it, but not fuse panel. Question 1: is there a fuse for the trailer brakes only? Question 2. Where would that fuse be located? Question 3. Is there anything else that would cause the brakes to not work at all?
  • Assuming you have the FACTORY trailer tow wiring, see page 194-199 of the 2004 F350 Owner's Manual. Position 101 is correct.
    From page 194,
    Passenger compartment fuse panel / power distribution box
    The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses. To remove the fuse panel cover, turn the panel fasteners counterclockwise.
  • What type of brake controller do you have?
    Does the brake controller light up when operated manually?
    Some after-market have an in-line fuse. Trace the wire from controller to truck connection.
    Check the wire from the brake light switch to the controller.
    Integrated brake controller should have fuse in trucks fuse block. 2004 maybe the one left of steering column under the dash.
    Do not confuse a 30 amp trailer power feed with brake.
  • Should be a fuse box diagram in your owners manual, showing each fuse and function.
    I would use a multi-meter to test, starting at truck connection. A simple 12V light tester should show current, while helper is applying brakes. If good, I'd move on to junction box, near pin box, that cord goes into, to check for brake wire power.
    Jerry
  • There is a 30 amp fuse listed for your truck. Should be position 101 and it is a large fuse not one of the Mini fuses. Look under the hood most likely on the drivers side for the power distribution fuse box. It is rather long. A bad ground could possibly cause the brakes not to work. Do the running lights work on the trailer? Check the brake wiring at or on the axles. Possible the wire insulation may have worn away and bare wire to metal grounding.
