The diesel will certainly out pull the gasser with an 8000lb trailer. The 6.2 would pull that with no problems. I pull 10K and never wished I had a diesel.
If you have the extra money ($10K+) for the diesel? Go for it but I would recommend you get a 350. The diesel really eats up payload in a 250. You will be in the low 2000lb payload range with a 250 diesel. Since you would have the extra $10k for the diesel, an extra $600ish for the 350 shouldn't be a problem.
S
