beachbum5
Mar 15, 2015Explorer
Gas VS Diesel F250
I am looking at new F250, I have f wheel about 8000lbs. I would like to know gas mileage while towing and not towing, also on diesel. How would gas handle the load? Thanks
Water-Bug wrote:brooks379 wrote:shepstone wrote:
Wait till you get to pay out for , belt tensioners, turbo oil lines, fuel filters, the water pump on my 7.3 literally grenade'd and took a bunch of other stuff with it and scarred up the rad that was over 2g's. Over the 5 years I had it it cost me over well over 5 thousand in just the engine related repairs without the tows or maintenance costs, or the downtime for my business, there is a lot of money lost when you got 5 guys on the jobsite being held up and having to shut down, even for only a day, but you still gotta pay them. These are not even major repairs when it comes to a diesel no matter what brand. Sure it can happen with a gasser to but not nearly as much cost and downtime. My 6.0 Savvana has been in the shop twice in 4 yrs one for ball joint @$400 and one for corrosion on a connector under the fuse panel@$200 no engine related issues at all and no shut downs. Almost no const companys own diesels around here I know cause I work with most of them and neither do the utilities. & if you think that a diesel in Ontario gets better value when you sell it then think again cause rust is a great equalizer and it doesn't care what engine is in the truck
No Construction company's or Utility company's own diesel pickups.....must be a Canada thing. They ALL own them here !!
It IS a Canada thing. Diesel fuel gels below zero and utility companies cannot plug in block heaters, when out on a job.
