fulltime5er wrote:
Lantley wrote:
I currently have a built in Onan LP genset. Works very well.Simple push button convenience. No cords,cables, locks,no gas tanks etc. Perfect for quick breaks and spontaneous use. WE can eat at a restaurant while traveling and leave the dog inside RV with A./C on. We can eat in the trailer with A/C and microwave 5500 Onan will run entire trailer including both A/C units.
On my prior TT I had a Robin Subaru 4300is mounted on a rear platform. This set up was not quite as convenient or powerful but worked very well. Genset was semi permanently mounted. There were no security issues. I had to plug in trailer vs. current push button start. I also had to have gasoline for the genset vs. lp which is already on board.
In the end I prefer the genset to be attached to the trailer vs.the truck. If the truck leaves the power is still with the trailer. I prefer the genset to be mounted to avoid any set up or carrying of the genset. A mounted genset is more convenient to use . It requires no preparation to use it. It can be used spontaneously without a lot of thought or set up.As a result we use more often.
How long can you run those on a 30# propane tank?
My 5'er came factory with 4-20# tanks. My unscientific usage seems to be about 6-8 hours per tank.
If you need to run your genny constantly 24/7 for multiple days on a regular basis lp may not be the way to go from a consumption stand point.
However if your a weekend camper with periodic genset use or you don't use genset for long periods regularly, lp may meet your needs. lp is clean and doesn't create carburetor issues that often plague gensets. Lp gensets can also sit idle for longer periods without having to deal with stale gas issues.
lp is already present on most RV's and is readily available without using additional tanks.
