RoyBell
Aug 15, 2019Explorer
Good hitch for SB Ram/Momentum combo
I am not getting much response to this question on the ram/GD forums so I figured I would try here.
I currently have a 2016 Ram Megacab with no hitch system in the bed. When I ordered it , I said I would never need a 5th wheel......Well, here we are with a 320G on order.
During my research, it appears the happiest folks are those with a gooseball and goosebox on the trailer.
My biggest concern is not having decent clearance with the 320G, even if I use the 4" offset ball. Does anyone have this setup with a 320g/350g? It appears most of the toy haulers have a similar cap though so maybe any momentum would be the same?
Looks like my other option is to get something like a B&W Companion slider hitch. It still mounts to a gooseball so I think I am pretty safe at least putting the gooseball in. Except I don't get an airbag on the hitch like the goosebox unless I change the king pin....It's an extra $1000 and more BS to deal with, heavier hitch, but I know it will have enough clearance then. The 320G is pretty short @ 36'. My Bumper pull is 34' and I never had much issue getting into any site we had...but we do plan on going to new areas with the bigger camper. Is the need for 90 degree clearance that overrated? Will a gooseball and goosebox get me close?
Option 1
B&W Turnover- $480
4" offset ball- $180
Goosebox- $1400
Total: $2,060
Option 2
B&W Turnover- $480
B&W Companion slider- $1500
Trailair air-bag King pin- $1100
Total: $3,080
I read all the posts that go back and forth on best options, but not too many have the SB Ram and a Momentum. My ideal setup is option 1 since it's cheaper and much cleaner. However, if I am going to have a hell of a time with the SB, then I rather bite the bullet on the slider.
The momentum looks like the cap is cut pretty good for SB trucks, so I would like think I should be pretty safe...unfortunately that's a lot of coin to drop to find out I was wrong and the 2 options are not compatible.
Option 1
B&W Turnover- $480
Goosebox- $1400
Total: $2,060
Option 2
B&W Turnover- $480
Total: $3,080
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
