94-D2
Aug 16, 2019Explorer
Her goes, (little bit shy about posting this kind of stuff on here)
I pull with the same truck (2018 Ram SB). I am not a fan of the conversions because they weren't designed to be a goose neck (frame engineering is designed different on a goose neck than a 5 th wheel) and the adapters I have seen fail in a crash.
So, when I bought my new truck, I already had a Superglide 2700. I had the puck system installed in the ram and at the time, they did not have a comparable puck mounted slider. So, I installed an adapter puck frame on the Ram and put the 2700 in the bed. Still works great with no issues now for over a year. Superglide is making the 2315 now with a price tag of about 2k. It is a bit overkill since it is a 24k hitch but better to have too much than too little to late. I talked to Pullrite about a light puck hitch and they said that is all they have right now.
As far as the gooseneck and turnover ball thing goes, I can’t really see why one would do it. I’m looking at it like an engineering thing (meaning these 5ers are not meant to be a goose neck otherwise the manufacturers would respond with the option in the main stream) and the ride quality and handling on the road is a Ford vs Chevy thing. My truck is equipped with OE air ride system on the 3500 series and rides like a big rig when loaded down with my Bighorn. When I’m not pulling, I drop air in the tires and it rides like a truck but is less bone jarring than when aired up. As far as chucking and popping goes, it creaks and pops a bit but who cares. The auto slide is there if I need it and so I never worry about hitting the cab. A co worker had a SB and manual B&W and of course, he didn’t use the slide and hit the cab (2017 Ram).
Good luck with whatever you do. FWIW, I’d stick with the way this rig was designed and stay with the 5th wheel and auto slider.
Happy Campin’
Happy Campin’
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
