Texas_Roadrunn1
Mar 20, 2017Explorer
Goodyear G114 Tires
We have these tires, Load Range H 17.5". Goodyear recommends 125 psi, max cold. Going down the road, TPMS showing 149 psi at 106*. Does anyone know the psi where we should become concerned about tire failure. We talked to Goodyear and the representative said if the tire was inflated to its maximum psi of 125, cold,and carrying the maximum load it is rated for, then you should not have to be concerned because the expansion is engineered into the tire. This seems to contradict the need for aTPMS, but since we have one we are trying to figure out where to set the upper psi limit. Does anyone have any verified information different from this. Thanks so much for your help.
