Walaby wrote:
MACHZER wrote:
They scale in Canada so they go more by payload than anything else.
As early mentioned, weight the truck full of gear and fuel and passengers
Subtract from your GVWR 10,000 for most 3/4 tons and there is your allowable pin weight
That simple
OP's not from Canada, unless PA stands for something other than Pennsylvania.
Two schools of thought.. those who swear by and live by the GVWR, and those who go by the GAWR. Your choice which way you go, but many folks (myself included) understand that the GVWR of a 3/4 is generally artificially capped at 10,000, and the truck is more capable than that. Hence the recommendation to use GAWR and not exceed that.
As others have said, you have weight on your rear axle with nothing in your bed. That is why you need to weigh the truck, full of fuel, and use the value that represents the drive axle weight. Subtract the drive axle weight from the GAWR, and that tells you how much capacity you have left for the pin weight of your 5er.
Mike
Yes, I am in Canada, however I was leaving Minneapolis going west on the interstate and just outside of the city, they where pulling over all trucks and RV's checking that emission components were on the truck and weighing trucks with Rv trailers, Funny, only weighted the truck with trailer attached. I was happy I was not in my deleted truck that time! I had no RV either but was watching others being scaled. Only thing they could be checking is GVWR
To the OP, do what you want of course its your rig!
You cannot change the gross payload of your truck no matter how you think it should work or how you want to play with the numbers
You truck LEGALLY cannot go over your GVWR, (10,000) with your trailer attached. That's why it's there on your sticker. You have an accident it could be a factor if a lawyer is on the ball which most are. I am going through the same thing now with my 2016 F350 SWR long box with a 11,500 GVWR, after I weighted the truck which came in at 9200, that only leaves me with only a payload or pin weight of 2,300. 5th wheel toy hauler now out the window
Again its your truck and ultimately you have to decide. Pick a great camper and have fun! Later
