Endricken
Jul 19, 2017Explorer
Sorry you bought a Reese Goosebox.
Mine lasted less than a year, as a massive pothole in West Texas broke my frame while using it.
Reese wouldn't replace the bent Goosebox (no longer usable) within the 1 year warranty - not their fault?....
Was glad to replace it the Star Performance adapter.
The Reese Goosebox airbag lost air after almost every tow as its pressure relief valve (only 45? PSI) would "puff" air out and refilling it was VERY slow via the "straw" like hose they supply - even with an air compressor.
Also they suggest you grease the coupler with every tow using the grease zerk on it.
WAY TOO MUCH Maintenance! And failed to protect my Fiver as promised.
Hope you have better luck!
About Fifth Wheel Group
