- Poppy_s_5th_WheExplorerGD does use Lippert frames and components. Lippert will only warranty their frames if you use the Reese Goose Box which should work perfectly for you.
- laknoxNomad
ScottG wrote:
Even if they OK it I would not do it. The forces are just too great.
JMHO.
Scott
x2! If you already have a GN ball in your truck, consider an Andersen Ultimate hitch, which uses the existing GN ball as an anchor point. Another alternative is a Reese "Goosebox" pinbox, which is an extended pin box with a GN receiver on the end of it. Lippert does OK this on =some= of their frames.
Lyle - ScottGNomadEven if they OK it I would not do it. The forces are just too great.
JMHO.
Scott - Coach-manExplorerI beleive Grand Design uses Lippert frames, which are the issue with gooseneck hitches. Call Grand Designs Customer Service, and ask your question. They are great at providing answers!
- romoreExplorer IICheck with the manufacturer, they will likely advise against it. Goose neck adapters put a strain on pin boxes they were never designed for. Go with it if you want but 'chucking' from flex may make your life miserable.
About Fifth Wheel Group
