Just had the guys at the shop pull my drums. Only one brake was working the other 3 covered in grease. Said I put to much in this spring. Metal on metal so don't over do it with grease
A little more info would be a wonderful thing. Like, did you do your own greasing? Were they the EZ Lube hubs? If so, how did you grease them? Technique is important. Debate about the EZ Lube hubs can be acrimonious at times, so the more data the better.
