lee_worsdell
Aug 03, 2017Explorer
greasing wheels
Just had the guys at the shop pull my drums. Only one brake was working the other 3 covered in grease. Said I put to much in this spring. Metal on metal so don't over do it with grease
Coach-man wrote:Shoot, that ain't gonna happen. I don't do that with any of my vehicles and I put a heck of a lot more miles on them than the toyhauler. After 6 years and about 15,000-20,000 miles everything looked fine: brakes, bearings, seals. I'm not about to start spending several hours every year pulling wheels from my triple axle toyhauler. That's a lot of time and effort, or money if I have someone do it. No thanks.
...Every year you should remove wheel and hub, clean and inspect brakes, check your seals, replace as required! ...
memtb wrote:
If they are the EZ-Lube, rolling/turning/spinning the tire is "pretty" much a must. Kind of a pain if you're by yourself. I'm going to take an old washing machine motor, fabricate a base with rollers, driven by a belt/pulley system (to spin tire slowly). Then simply place roller against tire, power-up the motor,spin the tire, and commence "greasing". Before anyone calls "bull" on the system, I have several trailers with the EZ-Lube system! The "spin, grease, repeat" gets a little old!
If that works for you that is great. But for me that is too much thinking, designing and work. Wheel bearing maintenance isn't rocket science. My prior trailer had EZ Lube and I didn't use it. Repacked the bearings, checked the brakes and repeated in 3 years. Each spring I raised the tires and checked end play and listened for unusual noise. Never had an issue and traded it off in 11 years with original parts and minimal labor.
fj12ryder wrote:OK and you don't pump your other vehicles bearings with grease either. Once you know it is done right it should be good for 5 to 10 years. Just inspected mine at 10 years and all was good. Replace the zerk with a plug and no more issues of greased shoes.Coach-man wrote:Shoot, that ain't gonna happen. I don't do that with any of my vehicles and I put a heck of a lot more miles on them than the toyhauler. After 6 years and about 15,000-20,000 miles everything looked fine: brakes, bearings, seals. I'm not about to start spending several hours every year pulling wheels from my triple axle toyhauler. That's a lot of time and effort, or money if I have someone do it. No thanks.
We'll just have to agree to disagree.
memtb wrote:
RAS43, I wish that was the extent of our work load around here. A large yard (irrigation, mowing, gardening, fruit trees, ect.), vehicle maintenance ( 2 rv's, boat, 2 UTV's, 4 wheeler, 3 trailers,tractor, 2 autos (truck and 4 Runner), rifles and handguns I don't have time to reload for and shoot. And those are just the highlighhts! We need to be "cloned", but that would be "clone abuse"! ;) Not sure why we have an rv... it's tough to find the time to use them! Sooo, had a "throw-away" washing machine and used the tub for a debris strainer on the irrigation pump and thought that the motor might come in handy to speed and ease the bearing lube proceedure on 3 trailers. :@
