BigDinAZ's avatar
BigDinAZ
Greetings and weight question
Greetings, Don here from Southeast AZ. We are looking to get a FW, but have no real rush because we want to research, and pick the best rig for us.
We just purchased our new 2018 Ram 2500 Laramie. 6.7 Cummins and a 3:73 rear end. I pulled the vin up on Ram towing guide and it says 17,100 LBS Max towing.
The GVWR is 10,000 lbs and rear axle Max is 6,000.
I understand the dry weight and GVWR weight as well as pin weight. So here is my question.
IF I get a trailer that has a GVWR of 16K lbs, and a pin weight under or at 2k lbs I should be okay right?
In other words the 16K LBS GVWR is under the 17,100 Max towing, and the pin weight of 2k lbs is under the 6K Max axle capacity. Am I correct in my thinking?
I want to make sure I am researching the right FW and weights BEFORE really looking.
Thanks in advance.
Don.
