CA_Traveler
Jan 19, 2022Explorer III
Check the battery voltage, plug in the RV and if it goes up the charger is at least partially working. Follow the heavy battery wires to the charger and research the model - if it exists. If the charger has AC output wiring then you have a charger/inverter. Turn on the inverter and if you have 120V AC output it's working. This all assumes you have batteries and they are OK.
Highly recommend you post on a HR board for help and you might even find wiring diagrams.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
