kennethwooster
May 05, 2013Explorer
Help from those with Super Glide using Slip Plate
Been working on way tubes to get off the old slip plate. I've noticed several pertty good scrapes that I can not sand out. They are peobably about 1.5 inches long, and can be felt when running my finger across it. Courses this is with most of the slip plate sanded off. Wiil this be a problem. I do know when I put it together I can make sure the scrapes are not carrying much of the load. Have you ever had to replace way tubes. My personal opinion is it won't hurt, but felt like I need to double check. I'm about ready to start applying slip plate. Thanks for any help.
