hmknightnc
Jun 08, 2014Explorer
How much bed to FW clearance do you have? I'd be adjusting my hitch clearance down to around 4 inches if you got more than that to reduce that 7" unlevel condition.
Also something is not right with your weight measurements. Attaching the FW should add slightly to the front axle weight not unload it like your measurements indicate. Is the center point of your FW hitch forward of the rear axle, it should be.
About Fifth Wheel Group
