stro1965
Jun 08, 2014Explorer
hmknightnc wrote:
How much bed to FW clearance do you have? I'd be adjusting my hitch clearance down to around 4 inches if you got more than that to reduce that 7" unlevel condition.
Also something is not right with your weight measurements. Attaching the FW should add slightly to the front axle weight not unload it like your measurements indicate. Is the center point of your FW hitch forward of the rear axle, it should be.
I only have about 5 or 6 inches bed clearance now, not much wiggle room at the hitch. Hitch is mounted forward of the truck axle. I was surprised at that too, but that's what the weigh sheets say.
About Fifth Wheel Group
