NC_Hauler
Jun 09, 2014Explorer
RCMAN46 wrote:
True pin weight is the difference of total truck weight with and without trailer attached. In the OP's case his hitch must be behind the centerline of the rear axle which results in unloading of the front axle.
Truck only is 5080 + 3380=8460
Truck with trailer is 4820+6080=10900
Thus the true pin is the difference of 2440.
Don't believe you're right on the pin weight number, ..You take the unloaded weight of the truck, you will get drive axle weight (rear axle)...then you hook the 5er up to the hitch and re weigh, the "PIN WEIGHT" of the 5er is considered the weight setting on the hitch, which is setting over or very near one's Rear axle..THUS the difference is what his empty weight of his rear axle was 3380, loaded it was 6080, thus pin weight is 6080,(the weight of the 5er setting in the hitch), less the unloaded weight of the drive 3380,(rear axle)...which give you 2700# of pin weight for his 5er
Look up what constitutes "pin weight"...I'm not talking total weight of the truck before and after, and even IF some weight were transferred to the front axle, (in which case, this one didn't), pin weight is still considered weight put ON the HITCH only.
One good point made by RCMAN46 was that possibly the OP weighed with slider hitch in back position...Definitely would skew the weight readings on front and rear axles, though Gross weight would remain the same.
About Fifth Wheel Group
